Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans done have a small issue!
Old 07-23-2011, 05:22 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by cudablack2004
tried 3rd also wasnt any better than 4th gear still locked up and loss power i think my car has 2.56 gears so ima do 3.73 and hook it back up after a few weeks when its done guess it'll hold up til then
if its doing the same thing in 3rd as it is in 4th gear when the tcc comes in then you have another problem. either an engine misfire or performance issue, or youve got a electrical problem with the tcc wiring, or you have an internal leak in the lockup circuit that is causing a bind when the tcc engages.
with 2.56 rear gears, in 3rd gear with tcc engaged, the engine ought to be running quite happy.
