better off running it in 3rd gear instead and letting lockup work like its supposed to. with lockup engaged, it allows lube to get to the planets so they dont get burned up.
tried 3rd also wasnt any better than 4th gear still locked up and loss power i think my car has 2.56 gears so ima do 3.73 and hook it back up after a few weeks when its done guess it'll hold up til then
with 2.56 rear gears, in 3rd gear with tcc engaged, the engine ought to be running quite happy. |
You said you have 22" Rims. What diameter are your tires?
As 'Tnsmith' said maybe electrical problem with the TCC Solenoid etc.. http://www.montecarloss.com/TCC_Solenoid.html |
Russ |
| Small Block Chevy stalling issue...... | Builtnotbought2010 | Hotrodding Basics | 13 | 08-02-2010 09:23 PM |
| ford small block bolt issue | tech.1979 | Engine | 3 | 08-02-2009 01:15 PM |
| 350 Trans Issue, Stalls engine in Reverse | mseifried | Transmission - Rearend | 12 | 04-14-2009 01:52 PM |
| Small block chevy main bearing issue (assembly) | JoshF | Engine | 11 | 06-20-2008 06:22 PM |
| 79 Trans Am Shaker Hood Scoop fit issue | Gladis | Body - Exterior | 3 | 03-07-2007 07:25 PM |
