Trans. Dyno - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2006, 07:00 PM
Trans. Dyno
I'd like to biuld a transmission dyno to test transmissions. Can it be done? Cost? Materials needed?
Old 06-04-2006, 08:42 PM
jakeshoe's Avatar
You could build a test stand with some type of running engine, a rearend (or motorhome style driveshaft mounted brake), driveshaft, adjustable stand, several pressure gauges, etc.
It would let you know the approx stall speed, shifting, shift timing, etc.
You could test pressures on the stand in each gear, or from each port anyway. Check for crossleaks, etc..
Old 06-04-2006, 09:00 PM
You can build a dyno, but I bet you can find a used one cheaper and easier.
Look in business journals and the regular paper for tech school sales ro trans shops that are liquidating. Depending on what you want to test, building a reliable, accurate and safe dyno will easily exceed $2000.00 in parts and labor. EXCELLENT fabrication skills and machine shop experience is required.
New Trans and Driveshaft - Truck moves when in park Z-Money Pit Transmission - Rearend 2 01-28-2006 08:04 PM
Dyno disaster lust4speed Transmission - Rearend 5 03-01-2005 06:55 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 02:29 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
