trans or floor jack??? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-12-2011, 06:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
There is no doubt a trans jack is the way to go, But i don't know how much money he has to spend and he probably already has a floor jack i assume.
And i have dropped a few myself with a floor jack and that's why i said to have a friend help. Sure if you have the funds and need a trans jack get one or rent one, still either way a friend present would be a good thing.JMO
Cole
  #17 (permalink)
Old 01-15-2011, 05:47 PM
Here is a picture of mine, Done lots of trannys with it.
  #18 (permalink)
Old 01-15-2011, 06:22 PM
eloc431962's Avatar
Wiki Edits: 37
Shoot that will work just fine.
Cole
  #19 (permalink)
Old 01-15-2011, 07:11 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
thats about what i have, ive got two jacks, a cheap parts store one with a plate about the same size welded to the foot/pad,
and a newer one from costco
and half the time we just use the cheap one with the plate for jacking up cars,you just work around it, and never take it off
  #20 (permalink)
Old 01-15-2011, 07:26 PM
Irelands child's Avatar
That's how I did my tranny - used my little 2T $19 trolley jack, welded on some angle iron and a couple of plates but have since put it back to normal though. If my HF does as well as that one, bought in 1987 and abused regularly, I'll be very happy.
Dave W
Irelands child
  #21 (permalink)
Old 01-15-2011, 09:29 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
sweet deal with the plate on top.I may try to build something like that later this week.I have 3 floor jacks one one being a racing jack.Ive never pulled a tranny before so Im gonna take my time with everything.
  #22 (permalink)
Old 01-17-2011, 09:11 PM
adamsautoadvice's Avatar
Adam's Auto Advice
Like others have said you can use a Floor Jack, but it can be tricky. I would recommend a Tran Adapter as well. It would be safer and much easier. You can still use the HF 20% Off Coupons on Trans Adapters.
  #23 (permalink)
Old 01-17-2011, 09:57 PM
two cups of tea
Wiki Edits: 2
Im allways at hf&never saw they had adapters for jacks there.I just went on there web site&some of the guys said in there reviews that you can only use it with certain jacks.I do have a hf racing jack I wonder if that one will work?
  #24 (permalink)
Old 01-18-2011, 12:15 PM
001mustang's Avatar
Trans adapter requires jack w/ removable saddle.
Sits in hole about 1" diameter?
Keep in mind that you will have to raise your car very high w/ adapter.
  #25 (permalink)
Old 01-19-2011, 05:52 AM
Wiki Edits: 27
trans jack
The good ones have a tilt for side to side and front to back. back in the day, I used to stack 40 tons of hay bales every day all summer long, I used to lay under the old ford and pull a T 85 overdrive and then roll it off my chest. after being gone from the ranch for 10 years I tried it again and the trans was chrushing my chest. I could hardly breathe. It was time for a good trans jack.
  #26 (permalink)
Old 01-19-2011, 06:10 AM
Originally Posted by timothale
The good ones have a tilt for side to side and front to back. back in the day, I used to stack 40 tons of hay bales every day all summer long, I used to lay under the old ford and pull a T 85 overdrive and then roll it off my chest. after being gone from the ranch for 10 years I tried it again and the trans was crushing my chest. I could hardly breathe. It was time for a good trans jack.
Don't remind me of days when I could do that - heck I can hardly lift myself from my Lazy-Boy and the newspaper some days. I should pull the leaky C4 out of my '31 and haven't figured out how to lift it without buying a jack ......... inspiration (or a trans jack) will eventually arrive
Dave W
Irelands child
Torin Black Jack 3-Ton Floor Jack and Stands adamsautoadvice Garage - Tools 11 01-21-2011 11:21 AM
3 ton floor jack hshad7 Garage - Tools 18 12-09-2008 05:11 PM
Hyd floor jack JAMES MEDLEY Garage - Tools 9 10-22-2008 05:17 PM
floor jack Mr.NutCase Garage - Tools 9 10-14-2005 10:32 PM
Floor Jack............. poncho62 Garage - Tools 9 12-30-2004 09:00 AM
