Trans fluid additive - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2008, 04:10 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
I wonder why Lubegard RED isn't compatible with Type F? They do state that on the bottle.
I'm no chemist, but I guess it may make the fluid TOO slippery. (?) Clutches may suffer?
Hmmm.
Old 05-21-2008, 11:13 PM
LubeGard
Type F is very old transmission fluid, I hope that you not using that in a newer vehicle. Type F has a very high content of Fiction Modifiers, and differnt fluid viscosity as per Saybolt testing specifications. If you put type F in a transmission that requies Mercon Dextron 3 4 or 5 that the transmission will have very harsh shifting concerns and accelerated clutch fibers and steels wear, as a result this will cause other internal transmision parts to fail faster. The LubeGard is fine and dandy for older transmissions its like and EOS or Slick 50 for transmissions.
LUBEGARD RED ATF PROTECTANT:
Reduces operating temperature, allowing transmissions to perform more efficiently
Increases thermal & oxidative stability of ATF for stop & go driving, heavy loads & towing
Reduces transmission wear, extends fluid & transmission life
Maximizes over all transmission performance
Helps reduce comeback & warranty problems for shops & mechanics
Insures proper & smooth shifts
Prevents clutch chatter & torque converter shudder
Eliminates objectionable noise (squawks) during shifts
Keeps valves free. Frees stuck valves in valve bodies
Prevents hung governors
Modifies harsh shifts & makes them quicker in duration
Can be used with all ATFs: OEM, Synthetic or Mineral Oil Based
Contains LXE (synthetic esters & synthetics)
Last edited by Crosley; 05-22-2008 at 07:17 AM. Reason: Copy-pasting. Please see: copy-pasting guidelines.
Old 05-22-2008, 12:35 AM
C-10's Avatar
Revolution Calling
Hey thanks for the reply,
I over analyze the details sometimes, way too much. Talking strictly from a hobbyist point of view. I build all my own transmissions for no other reasons than, I can. I like to see them tip top. Nowadays it's like alphabet soup with all the trans fluids out there. Personally I've always used type F for all the GM slush boxes I run- excluding the 4L60-E in my Camaro, but the old ones in the fleet get F. I'm considering trying something different with the latest 700R4 I built.
I may even make my own fluid! HA!
Old 05-22-2008, 06:54 AM
Wiki Edits: 31
B&M Trick shift is type F from what I'v heard.
Old 05-22-2008, 08:29 AM
Check out the Fordmuscle web site. They have a lot of info on the C4 transmission and the oils they use. Many use Mobil 1 in there box's. TF
