Trans Gear Ratio
I've checked the Knowledge Base to no avail. Does anyone know the gear ratios of the ever-popular and much sought after GM TH 200 trans? (Tongue stuck in cheek.) The Knowledge Base has every other GM trans.
Re: Trans Gear Ratio
LOOK HERE.......... http://www.tciauto.com/tech_info/gear_ratios.htm
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
It still doesn't have the 200. It has the 200R4. Are they the same ratios through the first to third gears?
=========== Yes. The back end of the gear train is the same design and ratio from the T-200 to the 200R4
At the Bonneville Salt Flats, first gear is known as 130 mph. |
