Trans howling - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2007, 07:31 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
Trans howling
I have been messing around with my '89 Audi 80 for some time trying to get it just right. Although I am almost there, it seems as if a new issue has cropped up.
This is the standard 2.0 FWD 3-speed combo. The trans was replaced a ways back and now has appx. 2,000 miles on it.
I am getting an extremely loud howling noise out of it upon load. When I accelerate or hold a steady spead she howls like a banshee, upon letting off the pedal it goes away...you can hear the gears load and unload somewhat like a granny gear in an old Ford.
Trans fluid looks good as well as diff fluid, and considering the expense that I put into this thing (I paid to have a shop supply a rebuilt)...what do you guys think?
I assume I will be pulling the trans, but just wondered if anyone had any thoughts...I am PO'd about tearing into a 2k trans with this low of miles.
Old 03-27-2007, 12:42 AM
brian0605's Avatar
mostly confused
Last journal entry:
probably in the differential side.How far back was it replaced? with that few of miles I would be looking into warranty?!?!Brian
Old 03-27-2007, 06:21 AM
Lonestar's Avatar
I will try to give a condensed version of the story.
I hired a top end import shop to replace the trans as the diff seal went out allowing gear oil to get sucked up into the trans...which quickly fried it.
The shop was supplied a trans from a rebuild shop that was supposed to have excellent reputation for in-house rebuilds.
Well, the trans was junk from day one...wouldn't shift out of first for like 2 miles, slipped in reverse, etc... The rebuild shop handled the warranty and kept changing fluid / filter while telling me "the trans filter was plugged, should be good to go". They did this multiple times.
I spent almost a year fighting with them over this, and they tried to blame the labor shop who I knew was not responsible. In the end, I managed to get a new trans and have the labor shop install it all free of charge.
The new trans started howling roughly two weeks after the warranty ran out...just my luck.
Needless to say I have been PO'd at the car and have been fiddling with it now and ten over the past few years. New engine, body work, etc...
Now I want to give it to my son to drive as he just started drivers training. So...
BTW, the labor shop quit doing business with the rebuild shop. The rebuild shop is also a large supplier of used parts, and I have to have others pick them up for me as they never wish to see me again.
Old 03-28-2007, 07:37 AM
Lonestar's Avatar
Oh, its in the differential side allright...a friend of mine suggested putting Lucas treatment in it. Any thoughts? I was never to keen on these types of products.
Cork would probably do the trick also
Old 03-28-2007, 06:47 PM
brian0605's Avatar
mostly confused
Last journal entry:
I am a big supporter of LUCAS. I put it in my wifes 98 GMC Safari rearend it was making noise, not a lot mind you, but some.It helped quiet it down. Before I put any more money into it I would fill it up with Lucas and let your son finish it on off. If it survives Great, if not I would probably see about cutting my losses. Because unless there is sentimental value for the car it's actual value is only 1500$ if every thing on the car is perfect. I just ran it through kelly blue book. With the rest of the car in excellent shape and needs trans it's value was about 900$. Well good luck. Brian
Old 03-29-2007, 06:18 AM
Lonestar's Avatar
Yes, I am well aware of the bluebook value of the car, which is exactly why I am not taking it into a shop. I will try some Lucas and see if it quiets things down...if not I will pull it apart myself and fix it.
Yeah, the car does have some sentimental value for me.
Plus, with the amount of dollars already into it I am kind of married to it now!
Do you know anything special about these particular trans-axles? I couldn't tell you the model number offhand, but it is a 3-speed auto FWD only - 1989.
Old 03-29-2007, 07:28 AM
brian0605's Avatar
mostly confused
Last journal entry:
I'm not that familiar with the audi product. I had a friend that had a very similar problem to what you are describing in a 98 chevy venture. He was able to replace the diff and put it back in. Do you think you might find one in the junk yard and buy it and just use the diff?? The rest of the trans sounds like it's working ok. Brian
Old 03-29-2007, 08:12 AM
Lonestar's Avatar
The only car like mine that I know of in this area is a manual, which I don't know if the diff is compatable...worth checking into I suppose.
The other option is getting a used unit from the morons that rebuilt the trans in the first place...and I think you can figure out how I feel about that!
Other than those two sources, things are pretty slim in this area.
Old 03-30-2007, 12:23 AM
brian0605's Avatar
mostly confused
Last journal entry:
"The other option is getting a used unit from the morons that rebuilt the trans in the first place" Come on tell us how you really feel!! stop sugar coating it!! LOL. Have you looked on e-bay or see if there is club for those cars online that might have what you need. Brian
Old 03-30-2007, 05:52 AM
Lonestar's Avatar
If I was to state directly how I feel about that, I would be banned for life from this board.
I check E-bay now and again and have yet to come across anything.
I will try Lucas, worst case I pull the trans and tear it down. Word is these are pretty simple to work on and there is a guy by me that is supposed to be real good with these cars...so we'll see what happens.
The trans is evidently an Audi 087 or 089...the VW version sits transverse in the car where mine does not, so I don't know how much is compatable between the two. I did find a master trans overhaul kit for $185...so pricing may not be all that bad either.
Old 03-30-2007, 08:42 AM
brian0605's Avatar
mostly confused
Last journal entry:
Good to here the parts aren't toooo expensive. I was always told AUDI was french for "Open your wallet sucker" well let me know how the lucas does. you can run it 100% in place of the gear oil. Brian
dipstick problems with 350 trans merowe Transmission - Rearend 5 08-15-2006 03:42 PM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-11-2006 11:24 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 02:29 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
