Trans ID ORION? manual 3 or 4 spd - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2009, 10:10 PM
Het guys I found this in the bone yard the other day, All the spots for the linkages are in the same place as a M21, T-10, or saginaw, but the cover to open her up is on the top of the tranny. Here's some digits from it
Main casting on case: ORION 2603150 then on the other side there's a tag that says KAP OU 2 1 (outside the tag very large)
Tailshaft: Tag R-LP-QO/ other side of TS 2601407 a weird little symbol and a vertical 3 right at the end.
I believe it to be a ford top loader of some kind but I'm a chevy guy and this ones throughin me for a loop. I'll try and post some photos shortly. Thanks
Danny
Old 01-02-2009, 10:53 PM
no body
you mean to tell me no one has seen these before ??? any info at all would be great...
Old 01-03-2009, 12:43 PM
Old 01-08-2009, 12:54 AM
Wiki Edits: 85
Danny
I am fairly sure out of the 100,000 plus transmissions I have owned in the last 25 years that I have had several of these.
However, the info you gave, in particular "KAP OU 2", is NOT correct so there is no way to determine what you have. By Ford definition it is IMPOSSIBLE for the first digit to be a "K" and I have NEVER seen a "P" in the third position. The "O" is not possible either since Ford never uses a letter "O" in ANY position for this type of tag number, although they do use it in other numbers. Most common letters are "A" and "B" with ford sometimes using "C", "D", "E", & "F". I don't ever recall seeing any other letters there.
Once you get correct information, you might want to use a search engine before asking here. Google can find all kinds of information faster than anyone here.
Old 01-08-2009, 09:46 AM
If it's out of a Ford and looks like a toploader. Then the ORION means its a 3 spd overdrive. Not junk but not built as strong as the toploader either. Go check out David Kee. http://www.davidkeetoploaders.com/imposters.htm
Old 01-21-2009, 08:41 AM
tailshaft code
Main casting on case: ORION 2603150 then on the other side there's a tag that says KAP OU 2 1 (outside the tag very large) these were OUTSIDE the tag I can try and up load a photo, buit i have no reason to make it up!!!!! It's as clear as water, why would I make up number when i'm trying to findout the ID
Old 01-21-2009, 08:59 AM
woodz428's Avatar
Troll Hunter
I can try and up load a photo, .
That would probably get the best responses and results. Most people that are familiar with a wide range of transmissions can at least determine origin from a pic...that will get you a place to start.
Old 01-26-2009, 08:22 AM
ask and you shall recieve..
pictures... I'll get some of the other sde of the main case too
Name:	motors and rear end 047.jpg
ID:	35878   Click image for larger version
Name:	motors and rear end 048.jpg
ID:	35879   Click image for larger version
Name:	motors and rear end 053.jpg
ID:	35880   Click image for larger version
Name:	motors and rear end 046.jpg
ID:	35881   Click image for larger version
Name:	motors and rear end 054.jpg
Old 01-26-2009, 11:14 PM
Wiki Edits: 85
Looks like a common RAN-type Ford 3 speed transmission to me. Are you able to get a good pic of the tag?
Galaxie automatic to manual trans conversion galaxieguy3 Transmission - Rearend 0 04-25-2007 08:45 PM
5 SPD manual wont install all the way KevinDeFouw Transmission - Rearend 8 06-08-2006 07:05 PM
Quadrajet carb manual or auto trans??? 67firebird Hotrodding Basics 1 11-25-2004 07:23 PM
Chevy SM465 Man 4 SPD Trans? swoo55 Transmission - Rearend 0 10-26-2003 05:07 PM
need help with manual trans ID Scuzzy Transmission - Rearend 3 10-02-2003 01:27 AM
