trans. identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2011, 10:28 PM
I have a trans that im unsure if its original to the car or not , the shifter indicator has green dots. indicting it was a green dot trans.
but the engine was not original to the car so im kinda hoping that its a regular c4 trans and not the green dot trans , because im pairing it with a 351 Cleveland for performance.
the only two casting numbers that i can find is 7a040a and 65ap-7006b
if these are not any way to make this determination then please some one help me figure this trans out and tell me a way to figure it out.
thanks
Old 10-05-2011, 12:22 AM
Ford Junkie's Avatar
No substitute for cubic inches
Transmission Information.
If you go to this post it has a picture id of all the ford trans by filter and shape of pan.
Tony
Old 10-05-2011, 12:38 AM
SSedan64's Avatar
I'm not a Ford guy, so the #'s don't mean anything to me. Someone may know how to ID it ex or internally tho'.
A while back there was a Thread about the Green dot Valvebody, try doing a search here.
May help >> http://www.raceabilene.com/kelly/hot...ns/fatlist.gif
http://www.fordification.com/bumpwik...Cruise-O-Matic
http://www.fordification.com/bumpwik...mage:Comid.gif
http://www.charlietranny.com/Fordomatic.htm
1992 gmc trans shot, will 1986 trans fit? Jamesace Transmission - Rearend 4 05-06-2010 02:42 AM
200-r4 trans identification lunaticwv Transmission - Rearend 1 09-09-2006 07:29 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
Identification of engine/trans combo thomasj392 Engine 3 12-11-2003 11:24 AM
GM Auto trans identification help? Pantera II Transmission - Rearend 1 12-02-2002 04:02 PM
