Trans knock???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2005, 02:04 AM
Trans knock????
i have a 1979 olds cutlass, with some 163,000 miles, 305 ci, th 350 trans, it just developed a knock today thats driving me crazy. It sounds like when a catalytic converter goes bad you know the tumbling marbles. Exept i dont have a catalytic. It sounds like its coming from the trans. Checked the brakes cause i just did them, they seem fine. Put the car on jackstands and the u joints seem good. The car only does it in drive under load (poking the throttle) it idles down the street but once i give a little gas it makes the soft knocking noise. I also gave it the brake and gas like your trying to smoke the tires happens then too, but never in park....does that rule out anything with the motor? I had a car whose fly wheel was cracked it sounded alot worse than my olds, maybe my converter?, im pretty stumped. Any help would be great, i'd like an idea what to look for before i tear everything down.
Old 10-25-2005, 12:18 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
there a dozens of things that could be going on there
I would check for
loose converter bolts/nuts
loose flywheel
loose transmission and or mounts
loose starter
something that sounds like a light knocking while going up the road can be alot louder than you think for the road noise
that should keep you occupied for a minute or two
hope this helps
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 10-25-2005, 06:09 PM
Jmark's Avatar
I had a cracked flex plate one time, sounded like what you are describing. Also pinging will do EXACTALLY what you are describing too. Check your timing, its an easy one to check.
Mark
Old 10-26-2005, 05:27 AM
Trans knock
thanks for the heads up, wish i could jump on it, but i leave in the morning for vegas. So wish me luck on both accounts, i'll let you know how the cars goes when i get back!
Car-toons I mean tunes! kringold Hotrodders' Lounge 107 10-20-2006 09:10 PM
Chevy 350 knock driver side? Help jimenezaldo Engine 18 09-01-2005 05:38 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 02:23 PM
