trans leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2006, 09:06 AM
blue85350's Avatar
My car took all my money
trans leak
just to rehash; i put a turbo 350 in a mid 80's camaro daily driver, because the 700r4 burned up. i put a new front seal in it and a pan gasket and now its leaking really bad like 2 quarts in less than 24 hours. and only when the car is not running. if the cars on it wont leak but off it leaks everytime. any ideas cause trans fluid is starting to get expensive and i get a discount on it
Old 12-24-2006, 09:13 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
when you installed the pan gasket, did you tighten it all the way down? or just till it moved a little? using silicone? cork or rubber gasket? i struggled with many a trans pan gaskets and finally wound up taking it to a trans shop and had them do it for me. hasn't leaked since. i wish felpro would make a polyurethane gasket with the anti-crush metal inserts for T350. i'd definitely buy one.
Old 12-24-2006, 09:18 AM
blue85350's Avatar
cork gasket, no silicone, all the way down and this is my first trans project( kinda, i do trans services at saturn but they're pretty idiot proof) so i really wasnt sure how far to go.
Old 12-24-2006, 09:26 AM
jvsapp's Avatar
how far did the gasket push out? from what i was told the gasket should move/pushout just a hair then you stop. but it has never worked out like that for me.
Old 12-24-2006, 09:29 AM
blue85350's Avatar
i dont really recall the gasket pushing out but i have to check cause i need the car thanks for the tip .
Old 12-24-2006, 11:36 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as the trans sits the converter will drain back into the trans pan........ anything above the pan rail can leak oil.
The filler tube
the detent cable
the shifter linkage
the speed-O bullet/housing
Around the pump to case seals and gasket
Old 12-26-2006, 10:21 PM
blue85350's Avatar
well i (with some help) seem to have figured it out. one of the bolts was too small and the way the gasket is designed the bolt holes are tight, so the bolt felt like it was tightening up but wasn't, i fixed it this afternoon and it hasn't leaked yet, but it may later(knock on wood).
Old 12-27-2006, 06:55 PM
blue85350's Avatar
it did leak later. i was supervised by my auto tech teacher at school, who told me that it didn't need a kickdown cable so it doesn't have one. think that might be the leak? i sure do. gotta get a kickdown cable and install that adjustable modulator.
Old 12-27-2006, 08:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If there is no detent cable ..... is there an open hole there?
Old 12-27-2006, 08:26 PM
blue85350's Avatar
apparently, my little brother was looking at it when i came home from work, ticked off that it drained 2 qts. in a day, and came in to tell me that. yeah open hole(sorry if i sound like an ***, but i'm on my second case of trans fluid in the last 2 weeks) anyway thanks to everyone for the help and suggestions
Old 12-28-2006, 02:48 AM
jvsapp's Avatar
i find that very interesting... teaching auto tech and giving advise... what is his background? is he ASE certified? there are some really good auto shop teachers, but it all depends on their background.
Old 12-28-2006, 06:42 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It is interesting on how the instructor tells you the cable is unneeded , so you leave a 3/8 inch hole open on the tranny case.
We had a customer go off on our counter help this past summer.... calling every body names , " I am gonna get a lawyer threat" ... all over a leaky 700r4 tranny, no shifts till high RPM....The kid had called our tech guy several times.
When we got his car on the lift , the filler tube was stuck in the case of the 700r4.... there was NO rubber sealing sleeve on the filler tube. The un-hooked TV cable was resting on the header ( melted).
The kid's dad called me a G-D liar when I explained the TV cable must be hooked up. I walked away & let the shop manager handle it.
Good luck with your car, you will get it done. It is just a large learning curve
Old 12-28-2006, 06:45 PM
blue85350's Avatar
well the teacher is older and he has been having steriod injections in his back, and has been in a lot of pain. so i really don't want to hold it against him, but that was bad advice.
Old 12-31-2006, 05:33 PM
blue85350's Avatar
put the kickdown cable in today, and guess what, no leaks. the car also seems to shift harder, and not as early. so it is coming together well. now about the convertor and engine........
Old 01-02-2007, 08:22 PM
That front seal is a very tempermental issue it needs to be put in very carefully. Check the converter where it contacts the seal sometimes it get wear or burs and eats the seal.
4L60E leak Grogetter Transmission - Rearend 9 09-11-2006 12:06 PM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-12-2006 12:24 AM
trans leak Lonestar Transmission - Rearend 11 07-20-2006 10:51 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 08:45 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-28-2003 12:50 AM
