trans leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2013, 03:27 PM
trans leak
76 F/bird 350 eng. th350 trans . Looks to be the dipstick tube seal leaking . What am I looking for ,an o-ring or some other type of seal ? Any suggestion on where to get one ? If it' an o-ring ,what size ? Thanks
Old 07-20-2013, 04:01 PM
Banned
first off you need to take it out and see what you have then go to the auto parts store and pick it up. this is a no brainer simple stuff.
Old 07-20-2013, 06:04 PM
sedanbob's Avatar
When you replace it, add a little sealer.
Old 07-20-2013, 08:22 PM
I just thought there was a certain size for it but it seems like you have to have the part with you to match up .
Old 07-20-2013, 09:29 PM
Banned
yes sir. you should always bring the part with you.
Old 07-21-2013, 08:12 AM
I'm a little suspicius of the shift shaft also . How much trouble is that to replace as long as we're in that area ? Thamnks
T-350 trans leak 39chevy Transmission - Rearend 10 05-07-2013 09:14 PM
trans leak blue85350 Transmission - Rearend 15 01-02-2007 08:47 PM
trans leak Lonestar Transmission - Rearend 11 07-20-2006 09:51 PM
Annoying trans leak Blob Transmission - Rearend 4 05-28-2006 05:02 PM
Trans leak jamn50 Transmission - Rearend 1 03-23-2005 06:44 PM
