Trans leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 07:41 PM
Trans leak
Gotta 350 turbo out of a 72 Chevelle in my 54 chevy 1/2 ton truck. Was doing some work on the front end. Had it jacked up in the front pretty high. Now I have trans fluid leaking around the speedo cable and drive shaft . Was it too full,or do I have seal issues. No leaks before.And no,I did not stand the truck on end,just a couple feet higher in the front. Thanks. Cary.
Old 03-23-2005, 07:44 PM
poncho62's Avatar
Wiki Edits: 5
I would check your speedo housing seals. there is an "O" ring and a small seal by the cable conection......wouldn't hurt to replace the rear driveshaft seal too.
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 03:29 PM
Vacuum Leak Detector rally4x4racer General Rodding Tech 1 02-11-2004 07:46 AM
79 Trans Am T-top leak RideDannyRide Interior 3 09-29-2003 05:45 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 02:23 PM
