Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans leak
Thread: trans leak
Old 07-07-2006, 08:02 PM
Ricky Rocket's Avatar
Ricky Rocket Ricky Rocket is offline
Drive it like a rental!
trans leak
You might also want to take a look at the 2-4 servo cover. I have had these leak only in 2nd and 4th gear (from my memory anyways!) Clean off the ATF, raise the vehicle, and run it though the gears. Start in Manual low (1st) then 2nd, etc. Watch carefully to see if it leaks only in one particular gear, not just idling in park.
Good luck,
