trans leak
A friend of mine threw a rod in his 1988 Chevy 1-ton truck. He asked me if I would install a reman motor for him, to which I agreed.
Since I had the engine out anyways, I took the opportunity to install a front pump seal on the trans and change the fluid / filter. With everything completed, I tuned the engine and drove it around a little before handing the keys back. Everything was great...ran and drove very well. I did find a small tranny leak in one of the lines going to the aftermarket cooler, so I fixed that. He drove the truck down to Ohio to do some work (he's a contractor) at which time he called me to tell me that he was blowing tons of smoke out of the exhaust. We had it towed back and upon my inspection, I found so much tranny fluid under the truck that it was actually dripping off the tail pipe. It looked as if someone pressure washed the entire underbody of the truck with the fluid. I pressure washed everything (with hot water), checked fluids (oil fine, trans down a bit) and ran the truck. I couldn't find a leak anywhere. I ran that thing for a good two hours with no drips, I drove it around a bit and still found no leaks. He had to use the truck again, so he drove it to Muskegon...same thing happened, tranny fluid everywhere. It is as if the leak only happens when the truck is subjected to a constant load for a certain duration of time. I have not pulled the tranny yet, but since I cannot pin point where this gusher is coming from I suppose I will have to. The only thing I can think of is that the front seal is alowing the converter to blast the stuff out...I don't see why, but who knows? Any thoughts? |
Maybe it is overheating and blowing it out of the overflow/vent. I think if the front seal was leaking it would leak all the time. You didnt say what model tranny it is but some of the chevys have an overflow/vent on the top. If it gets real hot a little fluid can cover a lot of area especially at highway speed.
Maybe the original leak is still leaking just not as bad. i would go back and look there first. |
trans leak
You might also want to take a look at the 2-4 servo cover. I have had these leak only in 2nd and 4th gear (from my memory anyways!) Clean off the ATF, raise the vehicle, and run it though the gears. Start in Manual low (1st) then 2nd, etc. Watch carefully to see if it leaks only in one particular gear, not just idling in park.
Good luck, Rick |
I have not been able to get any seal to leak, even with nominal driving around town.
Ricky, no leak visible there either. My best guess goes along the lines of the torque converter cracked... I just talked to him and "lo and behold", he has another trans and converter...I am going to swap them out so that the truck is usable AND I can spend some time identifying the problem. As usual, you guys on this site are great! I wish I was a more personable type of person. I know I come across quite dry to a lot of people. I hope to do this swap in the next couple of weeks, but he has another truck and I have a wedding coming up...so time is short right now. Maybe all you guys can figure out why I break the trans mounts on my 'Bird every time I get on it (the 1-2 shift destroys it everytime). Anywho, I will let you all know what I find. |
I purchased this truck last night for the cost of the new engine...good deal (if you can deal with 7 mpg).
Turns out it has a TH-400, not a 700-r4 (I forgot over the last year). This explains the fuel consumption. It came with a remanufactured trans which I am set to install this Sat. Here's the deal...it seams that this massive leak has been there since before I touched the truck. As it was told to me, the trans was pulled to r&r the front pump seal. Evidently, the person doing this pulled the (I forget the exact name for it offhand) bushing directly behind the seal along with the seal...broke his seal puller as it was told to me. Now, the owner was not informed of this and I never thought to look when I changed seals, so it seems to me that this is the problem. I am going to inform the previous owner if/when I verify this. To add, he quit driving the truck due to the distances he drives dayly and the cost of fuel...not because of the leak, so I do not feel bad purchasing it at a great price. Also, when I picked up the truck last night it seems someone dumped diesel fuel in it. Not a lot, but enough to make it run like crap. Such a shame to do to a 454 with 600 miles on it. |
Did the previous work done include bushing replacement ? Or did the guy that did the first job just do the seal?? If he gouged the bushing bad enough, he could have caused enough clearance to cause a leak under heavy load. The pump/converter bushing can have significant pressure behind it, and if the oil has somewhere to go, it will. That seal will only hold so much pressure and volume.
EDIT: I found this on ALLDATA, and it may relate - Quote:
Garth |
I guess he was scared that he trashed the entire trans and was hoping for the best. |
| Annoying trans leak | Blob | Transmission - Rearend | 4 | 05-28-2006 05:02 PM |
| Trans leak | jamn50 | Transmission - Rearend | 1 | 03-23-2005 06:44 PM |
| AOD into mustang | Stangman196700 | Transmission - Rearend | 3 | 12-16-2004 08:51 PM |
| Vacuum Leak Detector | rally4x4racer | General Rodding Tech | 1 | 02-11-2004 06:46 AM |
| 79 Trans Am T-top leak | RideDannyRide | Interior | 3 | 09-29-2003 04:45 PM |
