Trans locks wheels in R or N - will drive forwards - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 12:07 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Hi, guys! I know this is not a hotrod, but just looking for some info. I am looking at buying a 1993 Nissan Pathfinder for a winter ride, and the seller says the trans works in drive, through all forward ranges, but when put into reverse or neutral, it will lock the wheels. I don't know very much about import transmissions, and was wondering if there is anything inparticular I should be looking at. Could it be something like the manual valve being out of alignment and allowing fluid flow to try to engage a forward range as well as reverse when the shifter is put into reverse or neutral? I seem to remember something similar if you used the wrond "S" link in TH350's, but not being a trans specialist I could be mistaken. I have also heard mentioned a "lockout pin" that may cause this? Any of you trans gurus been inside these Nissan autos?
Old 01-30-2011, 05:29 AM
tnsmith10's Avatar
when will it rain???
if your getting a bind or no movement in reverse or it moves forward in neutral, odds are that the forward clutches are metal to metal and seized.
depending on mileage, and how well the previous owner kept up with maintenance, or the lack there of, its very likely that the problem is internal and it will need to be rebuilt.
as far as the internal linkage goes, theres no extra link to hook up the manual valve, its a direct hookup.
Old 01-31-2011, 10:43 AM
While not the news I wanted to hear, it is exactly the information I was looking for. Thanks, I think I may pass on the truck, unless I can get it for almost nothing. It has a bit over 250,000 miles on it, and if the trans is done, what will go next. Mind you, he is asking $450 OBO, so I may be able to pick it up for a song.....
Manual Door Locks to Elec Locks ryankalel General Rodding Tech 5 05-26-2008 05:29 AM
V8 S10 trans/drive shaft lumberjacknooj Transmission - Rearend 4 03-06-2007 04:28 PM
stairway to heaven, sung backwards, played forwards Jon Off-Topic 0 05-07-2006 12:24 PM
Front drive 3.8 Buick to rear drive trans Chopt 48 Engine 0 04-30-2006 02:43 PM
Trans bad in drive. Good in first. firewood Transmission - Rearend 2 02-13-2004 05:28 PM
