Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trans not going into gear cold
Old 12-06-2012, 01:12 PM
spinn's Avatar
spinn spinn is offline
My brothers car has a manual trans problem. The shifter will not go into any gear cold. When hot it shifts into gear. When it is off it shifts into gear cold. I have checked the fluid. It is new and proper level. I checked the clutch master and slave, and bled it to be sure. Thinking the plate was not disengauging from the flywheel, or that the master didnt have enough force to. Nothing replaced but it seemed the linkage was working. If I leave it in gear over night, start it, I can drive away. If I stop it will not go back in first till warmed up. If this was the synchro, would it not go into gear cold , engine off, like it does? The clutch holds and will stall the vehicle. I am not the trans master , but this has me . Any ideas on what this could be?
Now that it is cold it has become a serious problem. Warm it drives real nice.
