trans oil for 5 speed man
i have a 1988 chevy 1/2 ton pickup with a 5 speed trans {man}. ive heard of 3 types of oil to put in it . Mobil 1 syn auto trans fluid and something clear. i was wondering if Royal purple syn trans fluid wood work ? need some help on this dont want to hurt tranny. the tranny an bellhouseing is one unit. thanks for the help.
From another thread- "Chevrolet Truck 1988-92 5-speed: Sectional Case Gear Lubricant = GLS P.N.1052931 (This number is listed in the book) (Gear Lube,Special) Cross reference - 5W-30 or 10W-30 Engine Oil SG/CC/CD Capacity should be 1.9 qts., check to make sure by saving the drained oil and measuring it." And- "New Venture Gear 3500 Manual Transmission recommended lubricant: Synchromesh transmission fluid GM p/n 12345349 The oil capacity is 2.2 quarts or 2.0 liters." |
The Amsoil site calls for 5W-30 synchromesh transmission fluid in all manual transmissions for that truck except the NV4500, which your truck won't have anyway.
trans fluid
thanks for the info i feel much better knowing im putting the rite thing in my trans. thanks again
| All times are GMT -6. The time now is 04:46 AM. |
