trans oil for 5 speed man - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2011, 04:06 PM
i have a 1988 chevy 1/2 ton pickup with a 5 speed trans {man}. ive heard of 3 types of oil to put in it . Mobil 1 syn auto trans fluid and something clear. i was wondering if Royal purple syn trans fluid wood work ? need some help on this dont want to hurt tranny. the tranny an bellhouseing is one unit. thanks for the help.
Old 06-25-2011, 10:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
By what I can gather, a synchromesh manual transmission fluid is what's called for. It's not ATF. But a motor oil (synthetic fine) can be subbed.
From another thread-
"Chevrolet Truck 1988-92
5-speed: Sectional Case
Gear Lubricant = GLS P.N.1052931 (This number is listed in the book) (Gear Lube,Special)
Cross reference - 5W-30 or 10W-30 Engine Oil SG/CC/CD
Capacity should be 1.9 qts., check to make sure by saving the drained oil and measuring it."
And-
"New Venture Gear 3500 Manual Transmission recommended lubricant: Synchromesh transmission fluid GM p/n 12345349
The oil capacity is 2.2 quarts or 2.0 liters."
Old 06-26-2011, 12:17 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The Amsoil site calls for 5W-30 synchromesh transmission fluid in all manual transmissions for that truck except the NV4500, which your truck won't have anyway.
Old 06-26-2011, 12:38 PM
trans fluid
thanks for the info i feel much better knowing im putting the rite thing in my trans. thanks again
77 Trans Am 4-speed Tomlowe523 Transmission - Rearend 7 09-30-2009 08:23 PM
4 speed VS. 5 speed trans burtondemo Transmission - Rearend 4 08-18-2009 09:24 PM
5 speed trans My 57 Transmission - Rearend 3 05-22-2006 07:53 AM
5 speed gm trans twigg Transmission - Rearend 5 09-04-2004 11:22 PM
Trans Am 4 speed 68Velle Transmission - Rearend 4 08-25-2004 10:04 AM
