trans & pinion angle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2013, 12:22 PM
beachbum0's Avatar
First of all I know this has been beat in the ground, but I have to ask. Im familar with how to get my angles but I want to know if anyone has set the angles at 4 deg.? Becaus of the small block I droped into my 62 stepside, and to keep enough clearenc so I could drop the oil pan later I ended up with 4 deg. and my intake manifold to carb serface is tilted back 1 deg. I had to put 3 deg. shims on the differential pads to get 4 deg. up. Thanks for any answers By the way Got this far with the grill/head lights, but got to figure out how to put bars accross from the headlights that are concaved in.
ID:	75354   Click image for larger version
Name:	fixn ugly grill 017.JPG
trans. angle /pinion angle adjustments ? rf9763 Transmission - Rearend 6 09-24-2011 02:02 AM
pinion angle Cape Cod Bob Transmission - Rearend 2 09-24-2007 12:11 PM
Trans angle vs Rear angle with and without motor Tonythefish Transmission - Rearend 7 07-04-2007 08:17 AM
4-Link differential & Trans angle- with Pic 68NovaSS Transmission - Rearend 12 05-08-2007 07:05 AM
Pinion angle pace69 Transmission - Rearend 6 01-21-2005 07:46 PM
