Trans Plant Lt1 Into 1982 Mercedes 2 Dr. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 02:52 AM
I'm Looking For Motor Mounts, To Install A 1992, Chevy Lt1, Into A 1982 Mb380sec. Also, Any Information On How To Do The Complete Installation Of Engine, Computer, And 700r4 Trans, Into This Car?
Old 11-03-2011, 05:49 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Now that is different..several suppliers such as jegs, summit, speedway and some others have universal motor mounts. you will need to fabricate the chassis side of the mounts to fit your chassis. the crossmember will need to be modified most likely to allow the trans mount to bolt up and a custom driveline made to attach to a yoke for the 700r4 and the other end to attach to the Merc third member. Once all that is in then we can get on with the computer deal and that is a question all by itself.
Sam
tired of tranys going out! 1982 Blazer, t-350 trans K5hillbilly Transmission - Rearend 17 11-25-2010 12:55 AM
1982 k5 blazer w/305 want to install a 700R4 trans krubious Transmission - Rearend 4 07-08-2010 05:02 AM
1982 Trans Am W/ BW T 10 - using torque arm Trans Am Tony Transmission - Rearend 1 04-23-2007 06:39 PM
SBC in a 1982 Mercedes 300 D Nitrousbutton Engine 8 10-22-2006 05:36 PM
Pontiac Power Plant purepain Engine 1 11-24-2004 03:12 PM
