trans problem help!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2006, 03:32 PM
we just put together a 76 corvette it has a 355 sb with a tci turbo 400 tran with a manual valve body my problem is it is blowing the fluid out of the top of the filler tube its a new tranny been setting a couple of yrs any sugestions??
Old 08-18-2006, 08:17 PM
Sounds like a pump issue. T400 will vent pressure to the pan when the pump is damaged, causing your problem. This is a common 400 problem on hi perf/racing trans, especially if the converter was not correctly clearanced to the flywheel..
dipstick problems with 350 trans merowe Transmission - Rearend 5 08-15-2006 03:42 PM
engine problem after trans swap lt1bbody Engine 2 07-25-2005 01:01 PM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 10:21 AM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
Anyone know about t-45 manual trans? reverse problem Jason Transmission - Rearend 1 06-15-2003 02:14 PM
