Trans Probs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2002, 09:47 PM
Post Trans Probs
Hi guys im new to the board and I have a question...I have a 1978 F100 Ranger the transmission has never been re-worked or replaced.
When I go around curves, come to quick stops, and when I try to shift into reverse the trans seems to shift into nuetral and I have to tap the gas several times to get it to shift into gear agian. We have just replaced the fluid and filter (even used some trans-clean) and this improved the problem for a while but now its back and its worse. Does this sound like a stuck valve and if so does that mean its time for a re-work or is this a simple problem like a modulator valve.
Hope someone can make sense of this!!
Old 11-05-2002, 03:42 PM
Post
Ranger,
Neutralizes going around corners? Sounds like its low on fluid to me. Recheck it when its hot, in Park on level ground. Check it a couple of times, some Fords are tricky.
Old 11-05-2002, 04:55 PM
Post
Fluid level... kickdown adjustment...
Old 11-05-2002, 04:59 PM
BOBCRMAN@aol.com's Avatar
Post
how about wrong dipstick?
