Trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2010, 11:59 PM
farm truck's Avatar
Trans question
couple of questions, Which is a better trans turbo 350 or a powerglide . im working on a 1965 c10 short step side , im adding a 383 to her i have 411 p-track rearend . just woundering which would be better to use, an also which trans is easyer to perform better . Im not good at all with transmissions work. Any help i can get would help a great deal . Thank you
Old 12-30-2010, 12:17 AM
ericnova72's Avatar
More for Less Racer
How do you intend to use the truck?? Street use, with a trip to the track once in a while the TH-350 makes a better choice. Full on drag truck in bracket racing, the Powerglide might be the best choice, but the truck is just a bit on the heavy side to really work well with a Glide. Get the truck 1000 lbs lighter than stock and full drag use, the glide would work well.
Old 12-30-2010, 10:27 AM
farm truck's Avatar
trans
Thank you for your input . It will be street/strip. So i guess ill be useing a 350 . any ideal on what might be better to add to to trans to make it perform better at shifting ?
Old 12-30-2010, 01:00 PM
ericnova72's Avatar
More for Less Racer
A good shift kit, or a manual valvebody depending on how much control you want. If your making good power and torque(450+) you may want to get an aftermarket drum/intermediate sprag as the stock roller sprag/drum is the weak point in a TH-350. You lose second gear when it breaks the sprag, have to tear the trans down, clean it out, and replace drum.
BTE and TCI are two sourches I know of for the 36 element sprag/drum.
Old 12-30-2010, 01:33 PM
junior stocker's Avatar
Neither, a truck needs a TH400, or any heavier vehicle for that matter. After you replace/repair/rebuild a couple of TH350's, you'll agree.
Oh, and about your "handle"; do a YouTube.Com seach for "Oklahoma farmtruck" (farmtruck, one word); it's pretty impressive.
Old 12-30-2010, 01:41 PM
ericnova72's Avatar
More for Less Racer
Agree, this is really the place for a 400, I was just trying to give him a heads-up on the weak point in a 350.
I've seen video of that truck, ugly as sin and goes like stink!! Heard he has made a bunch of money grudge racing it until word got around.
T5 Trans Question tab Transmission - Rearend 40 04-12-2010 01:24 PM
200-4r trans question 75sprintguy Transmission - Rearend 4 09-16-2007 08:00 AM
trans question redlight101 Transmission - Rearend 1 02-04-2007 09:35 AM
trans question fattyford Transmission - Rearend 13 05-10-2006 04:42 AM
T-5 trans question classic_chevy_guy Transmission - Rearend 4 01-09-2004 12:05 PM
