Trans, and rear -end rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2002, 03:11 PM
New Member
Post Trans, and rear -end rebuild
i own a 1979 pontiac trans am 10 anniversary edition with a original 403 6.6L big block and a th-350 trans, and an 8.5" ring gear. what brand of trans rebuild kit, torque converter, and ad rear end rebuild kit should i go with??
Old 12-14-2002, 11:04 AM
axle bastard's Avatar
you're killin me buck!
Post
as far as rear stuff goes, richmond makes a good gear set, as does motive gear. i have found the motive gear stuff to be fussy as far as set up.
they seem to like to run on the higher side of the backlash spec. noticed this mostly with the ford 7.5 gearing.
motive gear makes a master kit, that includes the gear set, all bearings and seals ring gear bolts, and shims all in 1 box.
had good luck with drive train components stuff as well.
feel free to send me an email for help, parts, or whatever.
good luck, have fun!!
Josh
