Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 06-11-2005, 03:41 PM
Rocketmann66 Rocketmann66 is offline
Trans seems to shift into neutral during the 3-4 (overdrive) shift
Re: Ford Automatic Trans (AODE) - 3-4 (overdrive) shift problem -- After installing a shift kit and new overdrive servo, the 1-2 and 2-3 shifts are fine, but the trans seems to shift into neutral during the 3-4 (overdrive) shift. Prior to the shift kit, the trans failed/shuddered on the 3-4 shift. I have installed shift kits before without any problems. I’m wondering whether the shift kit has “uncovered” a pre-existing problem, or if this is possibly a problem with the MLPS. Any suggestions?
Old 06-11-2005, 06:17 PM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
re: Trans seems to shift into neutral during the 3-4 (overdrive) shift
What was the condition of the tranny before kit install? Weak shifts ? How many miles?
Perhaps the OD band is worn out
If you did not hold the OD band in place when installing the new OD servo, & verified the servo pin hit the band strut ......you missed the band. A very common thing on a shift improver install in the AODE / 4R70W
Lets say you verified the servo pin hitting the band strut..... which servo did you install? there are two sizes.
AODE & 4R70W use a smaller servo with a sleeve that slides into the OD servo bore. An early AOD design servo ( larger) slides into the bore with NO sleeve..... small servo with NO sleeve means a big pressure leak
IF all of the above is found to be A-OK..... re-check every thing on the install
Early MLPS could cause a tranny to seem to go into neutral when they were actually telling the PCM to command 1st gear..... year of your vehicle? Model?
Originally Posted by Rocketmann66
Re: Ford Automatic Trans (AODE) - 3-4 (overdrive) shift problem -- After installing a shift kit and new overdrive servo, the 1-2 and 2-3 shifts are fine, but the trans seems to shift into neutral during the 3-4 (overdrive) shift. Prior to the shift kit, the trans failed/shuddered on the 3-4 shift. I have installed shift kits before without any problems. I?m wondering whether the shift kit has ?uncovered? a pre-existing problem, or if this is possibly a problem with the MLPS. Any suggestions?
If you find yourself in a ditch.... down shift!
Old 06-12-2005, 09:21 AM
Thanks Crosley, this is VERY helpful!
Vehicle Information
Year: 1994
Make/Model: Ford Thunderbird
Mileage: 78K miles (actual – I’m the original owner)
Trans condition prior to kit install: Only problem was overdrive failure/shudder. A few years ago at about 50K, I fixed an erratic 1-2 shift with a shift kit, but the overdrive problem remained.
This time around, I added a few more “improvement” parts – e.g. the Sonnax Sure Cure Kit and a new OD servo. I used the “small” OD servo with sleeve, but I was unaware of aligning the OD servo pin with the band strut. So, I probably did miss the strut. Since I’m doing this work with the trans in the vehicle, I suppose there is no way to make sure the pin is properly aligned. Drat!!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Trans seems to shift into neutral during the 3-4 (overdrive) shift"
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 11:48 AM
trans shift kit chev kev Transmission - Rearend 4 02-08-2005 06:32 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 07:51 PM
Automatic trans does NOT shift automatically?! TH350 killerformula Transmission - Rearend 6 10-19-2004 07:31 AM
4l60e trans with shift improver BILLCAT Transmission - Rearend 0 07-12-2003 07:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
