trans shift kit 350 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2006, 07:35 PM
what you think removing two balls in valve body V.S. cheap kit
Old 01-25-2006, 08:16 PM
sbchevfreak's Avatar
Licenced Automotive Technician
This would be better in the transmission/rear end forum, however I'll give you my .02.
IMHO, the shift kit would be the better route. They all will come with detailed insructions, and new gaskets, revise seperator plates, and an oil redirection upgrade. Here, the B&M kit is less than $60 CDN, so I think it's kind of a no brainer.
Old 01-25-2006, 08:54 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
This might help:
http://www.hotroddersauctions.com/te...Shift_Kit.html
Old 01-26-2006, 09:16 AM
Wholio's Avatar
Drill the holes as in the last pictures. Take out all the check balls other than the ball that feeds the vacume mod. valve. Remove every third or fourth spring from the cluth packs and replace the wave rings with a regular clutch steel. Either beef up the spring under the side cover on the pass. side of the trans with a higher pressure spring. I think that the high pressure spring will have an orange stripe on it. You can remove the spring all together and replace it with an aluminum bar of the same diameter as the spring cut to not alow the piston behind the sping to move. Keep in mind freezing that piston will give you a very hard shift.
Old 01-26-2006, 10:03 AM
engineczar's Avatar
going to move this thread over to trannys
Old 01-26-2006, 06:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Removing the return springs in the clutch packs is a bad idea..
That can lead to the clutch pack applying at high RPM from centrifugal force of residual oil behind the piston in a spinning drum.
Turbo 350 Transmission Probs. Nixter63 Transmission - Rearend 1 09-27-2004 09:47 AM
turbo 350 wont shift joesnova2 Transmission - Rearend 22 07-18-2003 05:48 PM
turbo 350 auto trans Mike_67camaro Transmission - Rearend 1 06-21-2003 06:35 PM
rebuilding a turbo 350 trans. straycat60 Transmission - Rearend 2 03-12-2003 05:44 AM
Turbo 400 Shift Kit Recommendations loren Transmission - Rearend 2 09-28-2002 04:06 PM
