Trans shift problems
hello from the great white north , we also had a tranny shifting problem in my sons cutlass after changing the tranny . We went through all the adjustments carefully and it still would fall out of gear at a stop and some times not shift into od .Ihad a can of sea foam trans fix , we added that and after about 5 to 10 kms of driving it worked perfectly and still is , that was about a 1000 k ago and its still good . So take this for what it's worth if your tranny is good what have you got to lose ? Just make sure everthing else is good tv cable ajustment etc . Iwould sure try it . I have used lots of sea foam products and are very happy with them . Anyway good luck hope all goes well with the tranny . Later Bake
| 34 Plymouth Streetrod with 700 R4 trans shift problems | WirtzWiz | Transmission - Rearend | 1 | 07-06-2012 06:03 AM |
| 1981 Jeep j10 trans shift & slippage problems | jeep1981 | Transmission - Rearend | 1 | 07-14-2011 12:08 PM |
| 2000 Lincoln Continental trans shift problems | mbooom1 | Transmission - Rearend | 1 | 11-28-2008 04:19 PM |
| trans shift | steve t | Transmission - Rearend | 1 | 09-17-2005 12:42 PM |
| Trans seems to shift into neutral during the 3-4 (overdrive) shift | Rocketmann66 | Transmission - Rearend | 2 | 06-12-2005 10:21 AM |
