trans shifting? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2007, 04:54 PM
trans shifting?
87 GMC S-15, 700 R trans. While driving 50/60 mph. I suddenly noticed eng RPM's high. To my dismay trans wasn't shifting up into 3rd or 4th/OD. Manually & in drive it shifts up through 2nd & sometimes 3rd. But ,in 3rd only it stays in,up to a higher RPM 2500-3500 +-, than kicks out like into nutral. I can start over from 1st,ect & repeat the same thing. Fluid is a little burnt but not low or ugly smelling or looking. I've had the plesure of burn fluid nose bite. remember? Eng is a 2.8. Veh has 107000 miles on it. very clean inside & out. ( I know, put my full size blazer 305 & 700 R eng in it!) Any thoughts? Chuck,
Old 07-24-2007, 07:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
sounds like typical 3-4 clutch failure in the 700 trans.
a rebuild is in sight for this unit.
Old 07-24-2007, 09:11 PM
trans shifting
I was starting to feel like the need to remove & tear down a trans was coming over me. I think your right. Wouldn't hurt anyways. chuck
Old 07-24-2007, 10:16 PM
JeffB's Avatar
700R4 build
Been in your shoes,the 3-4 clutch pack is toast.When you rebuild it you might want to check out this ebay store.Oregon Transmission, get the Red Eagle Masterkit and a Transgo reprograming kit his prices are great! I used him and was very satisfied.Be sure and get the TV cable shop adjusted with a gauge 700's can destruct fast if TV is wrong.
Old 07-24-2007, 11:57 PM
jakeshoe's Avatar
While I have used the Alto Red clutches with success in other units, those in the know don't use them in the 700-R4 for the 3-4 pack.
Crosley being one with lots of practice...
The Raybestos Z-pack is recommended and a few builders talk highly of the stock Borg Warner Hi-Energy in an 8 count pack with thick steels.
I've used the Z-pack but haven't tried the Hi-Energy in anything other than the stock configuration. Most of my 700 builds are not for extreme performance use.
Old 07-25-2007, 06:39 PM
JeffB's Avatar
Red Eagle Clutches
Since the Red Eagle clutch pack has more clutches than other brands it is critical that the clearances be changed,the folks at Oregon Trans. put a big note in with my order alerting me to this,also when building a 700r4 don't forget "The Beast" .
Old 07-25-2007, 07:03 PM
jakeshoe's Avatar
I would bet Crosley has tried different clearances.
Old 07-25-2007, 07:23 PM
trans shifting
Thanks guys, I will take all this info & put it to good use. I'm going to ck on the diff. kits that is suggested & if I can add anything to this situation. I well.
As always good INFOMATION deserves RECOGNITION. Thank You Chuck
Old 07-25-2007, 07:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am told the Z pak is discontinued at the moment.... a re-engineering is happening.
Red Alto with standard steel plates works well. Scuff the steel up with a 3M pad or similar.
I like the hi-energy plates.
Shifting Problems jackson.king Transmission - Rearend 3 03-03-2007 11:53 AM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 08:27 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 08:45 PM
camaro transmission still not shifting chevcamz28newbie Transmission - Rearend 2 07-20-2003 08:33 AM
