Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trans slips out of overdrive under NO LOAD?
Old 08-27-2007, 02:52 PM
Ohio-Dan Ohio-Dan is offline
My guess, is that your throttle is at such a low position the the idle switch is activated causing the converter to un-lock. When you ease back into the throttle, the converter locks back up and drops your RPM's.....Dan
