Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Trans slips out of overdrive under NO LOAD?
Old 08-27-2007, 03:24 PM
weirdbeard's Avatar
weirdbeard weirdbeard is offline
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Originally Posted by Chazmac
Under light load that trans is programmed to have minimal line pressure, among other control changes.
A test drive with scanner installed is required to to determine if it is 4th gear slip or TCC slip (more likely). Either way, have an experienced tech evaluate it. Soon.
What kind of scanner? I have a obd2 actron scanner. Could I use that. Would the repair for this involve removing the trans.?
