Trans Spins One Direction in Neutral - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2012, 06:35 PM
SpeedRacer350's Avatar
Pedal Masher
I just got my 700R4 built to the hilt by a local shop. It took me 3 months to get it back in the car. Tonight I'm installing the drive shaft and noticed that it will only spin in one direction with the trans in neutral. The transmission is dry except for a half quart in the converter. I'm starting to panic. What do you all think could be wrong?
Old 12-02-2012, 06:50 PM
Pedal Masher
Never mind. I got it to turn with a pry bar. It was tough, but it'll move. It must just be a little tight from the fresh rebuild. Whew. The heart attack is going away now.
Old 12-02-2012, 09:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You're prolly fine: spinning 4l60e output shaft
Old 12-02-2012, 10:25 PM
Pedal Masher
Ha, that poor guy was in the same situation as me. Now I know that it takes a little more muscle to turn it clockwise. Weird. You just gotta learn this stuff the hard way. thanks.
Starter just spins. stroker444 Engine 4 04-01-2010 12:37 PM
4l60e trans neutral safety switch probie302 Electrical 1 10-31-2009 04:30 PM
TH350 trans problem, goes to neutral Some Car Guy Transmission - Rearend 2 09-21-2007 12:08 AM
Trans seems to shift into neutral during the 3-4 (overdrive) shift Rocketmann66 Transmission - Rearend 2 06-12-2005 11:21 AM
C4 Trans Neutral Safety Switch Beau Stang Hotrodding Basics 1 08-19-2004 07:03 AM
