trans start up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 03:00 PM
New Member
trans start up
need help whats the procedure for starting up a rebuilt 400 turbo trans adding oil etc.
Old 07-07-2005, 04:34 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
new install
fill converter with as much as i can put in
i always make Dur the converter is in all the way into the pump
a few into the dipstick hole
and fire that mother up
check for leaks
check fluid
check for gears
check fluid
check for leaks
wait till warmed up top off and should be all done
hope this helps
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-08-2005, 01:08 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
this might help
http://www.tciauto.com/tech_info/fluid_capacity.htm
Old 07-08-2005, 08:48 PM
New Member
trans
thanks for info
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
Won't Start fasano89 Engine 4 11-28-2004 12:57 PM
Motor And Trans In Baby!!! Ghetto Jet Hotrodders' Lounge 11 10-08-2004 08:06 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 08:45 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-28-2003 12:50 AM
