Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans started slipping after putting in a new pump
Old 06-26-2012, 10:06 AM
gaurdian101 gaurdian101 is offline
I have a th350 trans that i blew the pump gears up well got a new pump took the trans housing apart clutches drums etc. all but the valve body only because i'm afraid to play with it cleaned put back together any way ran fine for a day then started slipping pulled the tranny out clutch burnt go figure well took back apart this time took the valve body apart looking for any metal found some of that, found a valve stuck in the valve body would this make my trans slip?haven't pulled the governor apart yet maybe it's that?
