trans suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2006, 01:02 AM
86078's Avatar
you lift,you lose!
trans suggestions
what trans would you use to back a
mildly built 283??? i got a t350 on it
now...works decent...just researching
keep in mind that Hawaii doesn't have
those wide open interstates that most
you are used to...... thanks Kimo
Old 02-16-2006, 12:18 PM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
the T350 will work fine... strong enough for that 283... you just would need a shift kit possible later on... but then again maybe you might want to row some gears...
Old 02-16-2006, 01:48 PM
86078's Avatar
you lift,you lose!
haha...first you give me da left,right,left combo...
then you sneak in the uppercut KO punch huh???
Old 02-16-2006, 01:49 PM
jvsapp's Avatar
nah... just wanted you to feel welcomed....
Old 02-16-2006, 01:57 PM
86078's Avatar
you lift,you lose!
thankz man...
Old 02-16-2006, 07:27 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
stick with the 350 if you don't need OD. Get a lockup converter type if you can.
Old 02-16-2006, 07:38 PM
jvsapp's Avatar
hey dude,
remember i still got those 2004R's that judd never called me to come and git... so possibly you could have one if you wanted... but you can't have my T5.. sorry....
Old 02-16-2006, 11:52 PM
86078's Avatar
you lift,you lose!
Brudder,
Kinda think of sticking with the t350...maybe adding a shift kit...
but if i were to use a 2004r what kinda changes would i need to make???
ie: trans x-member,driveshaft,kickdown,etc???
Old 02-17-2006, 11:39 AM
RippinRon's Avatar
the 200-4rs are the same length as the th350 so the driveshaft will work but the cross member will have to me moved either forward or back a bit. You'll need a throttle valve cable (not a kickdown) to be adjusted properly or you'll burn up the 200-4r in a hurry. Bowtie overdrives make a adjustable cable and bracket for different types of carbs. The 200-4r has a nice ratio put in some 4.11 gears to get that 283 spinning and have fun.
Old 02-17-2006, 11:47 AM
86078's Avatar
you lift,you lose!
AAAhhh...New knowledge for me ...Thanks for your reply RippinRob
Old 02-17-2006, 11:49 AM
86078's Avatar
you lift,you lose!
Sorry,i meant Ron
Old 02-18-2006, 12:33 AM
jvsapp's Avatar
oh no... no 4.11's... not for the beer runner.... that would put the wheels too high in the air...
Old 02-18-2006, 01:28 AM
86078's Avatar
you lift,you lose!
two e-brakes for the rear wheels...
Old 02-18-2006, 01:54 AM
jvsapp's Avatar
huh... you getting posts confused?
Old 02-18-2006, 02:19 AM
86078's Avatar
you lift,you lose!
No.. i meant wheels in the air,
use two e-brakes (one each side) for
steering...
Car-toons I mean tunes! kringold Hotrodders' Lounge 107 10-20-2006 09:10 PM
New Trans and Driveshaft - Truck moves when in park Z-Money Pit Transmission - Rearend 2 01-28-2006 09:04 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
350 trans rebuild? jwart Transmission - Rearend 0 09-21-2003 09:06 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 02:23 PM
