trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2007, 05:34 PM
trans swap
Can anyone help me out on this promlem?
What i need to know is i have a 41 dodge coupe with a chevy 350 trans thats leaking bad and what i want to do is replace it with a fresh rebuilt 7004r that i have. what i need to now is do i need to replace the yoke on my drive shaft? do i have to modify my trans mount? the car is subframed with a 72 nova front end,
Old 03-27-2007, 06:37 PM
TailGater's Avatar
Blood, Sweat, and Gears!
If i recall corectly, the yoke should be the same for the 700r4 and the th-350, however i believe the 700 is a bit longer then the 350 so you will probably have to have your driveshaft shortened. I think the trans cross member will also have to be moved.
Hope this helps,
Chris
80 Trans Am Engine Swap normanm4 Engine 9 10-17-2006 04:26 PM
87 Trans Am Engine Swap Miserlou57 General Rodding Tech 3 02-01-2005 04:32 PM
Trans Am Engine Swap Guitarman Engine 2 04-26-2003 08:54 AM
c4 trans swap FASTFORD Transmission - Rearend 3 05-07-2002 12:11 PM
