trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-19-2003, 03:02 PM
rizzo59's Avatar
New Member
trans swap
i have a 59 belair with a ironglide trans, if swap a aluminum powerglide for this trans will it help in take off since this trans is lighter...daily driven
Old 12-19-2003, 04:21 PM
Not much...if any.....
The main improvement is weight loss...but not enough to be worth it IMHO.
A turbo 350 would be a step up in that heavy a car.
It has a 2.52 ratio 1st gear and the PG is less than 2 to 1.
That a big difference when multiplied by the rear end ratio.
