Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans swap, 400 trans in 83 elcamino?
Old 10-06-2011, 02:51 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
It will fit with a stock 84-88 G-body Crossmember for a TH2004R Trans. Your 83 will probably need the Frame extension added, these are available from Summit, Jegs, Iceman etc..
http://www.maliburacing.com/iceman/
http://www.summitracing.com/parts/SUM-770307/
DriveShaft will need to be shortened and Yoke changed, TH400 has 32-spline Yoke. A shorter Yoke may be available to avoid shortening the DS.
Trans Swap Info>> http://www.maliburacing.com/transmission_swaps.html
http://www.maliburacing.com/auto_tranny_id.htm
