-   -   trans swap, 400 trans in 83 elcamino? (http://www.hotrodders.com/forum/trans-swap-400-trans-83-elcamino-206657.html)
renagade 10-05-2011 11:27 PM
any one put 400 trans in 83 elcamino?
SSedan64 10-06-2011 03:51 AM
It will fit with a stock 84-88 G-body Crossmember for a TH2004R Trans. Your 83 will probably need the Frame extension added, these are available from Summit, Jegs, Iceman etc..
http://www.maliburacing.com/iceman/
http://www.summitracing.com/parts/SUM-770307/
DriveShaft will need to be shortened and Yoke changed, TH400 has 32-spline Yoke. A shorter Yoke may be available to avoid shortening the DS.
Trans Swap Info>> http://www.maliburacing.com/transmission_swaps.html
http://www.maliburacing.com/auto_tranny_id.htm
renagade 10-07-2011 10:45 AM
400 trans
Thanks for Information. I was going to modify my cross member. Your way sounds better Renagade
