trans swap, 400 trans in 83 elcamino? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2011, 10:27 PM
any one put 400 trans in 83 elcamino?
Old 10-06-2011, 02:51 AM
SSedan64's Avatar
It will fit with a stock 84-88 G-body Crossmember for a TH2004R Trans. Your 83 will probably need the Frame extension added, these are available from Summit, Jegs, Iceman etc..
http://www.maliburacing.com/iceman/
http://www.summitracing.com/parts/SUM-770307/
DriveShaft will need to be shortened and Yoke changed, TH400 has 32-spline Yoke. A shorter Yoke may be available to avoid shortening the DS.
Trans Swap Info>> http://www.maliburacing.com/transmission_swaps.html
http://www.maliburacing.com/auto_tranny_id.htm
Old 10-07-2011, 09:45 AM
400 trans
Thanks for Information. I was going to modify my cross member. Your way sounds better Renagade
ID a 3 speed manual trans, 1981 ElCamino 81ElCaminoFan Transmission - Rearend 1 02-13-2011 10:36 PM
trans swap oldskl46 Transmission - Rearend 1 03-27-2007 05:37 PM
250 trans swap to 350? drumharddriveanova Transmission - Rearend 1 08-25-2006 10:16 PM
trans swap laserline350 Transmission - Rearend 5 01-14-2005 10:55 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
