trans swap for 50 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 07:53 PM
Is there any easy trans swap I can do for 50 chevy to run a 4 ssspeed and do away with the torque tube? i have heard you can use an old s10 trans
Old 11-27-2007, 08:28 PM
are you wanting an automatic or a standard shift?
Shane
Old 11-27-2007, 08:34 PM
poncho62's Avatar
Wiki Edits: 5
welcome........I am moving this to the tranny forum.
Old 11-27-2007, 08:35 PM
Wiki Edits: 31
swap in a Camero rear end, and a T 10 4spd will fit on the engine with the correct clutch and stuff
chevy monza trans swap dcoates18481 Transmission - Rearend 2 09-09-2007 10:42 PM
1953 chevy frame swap Bwagner General Rodding Tech 3 07-01-2004 09:35 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 12:14 PM
trans swap rizzo59 Transmission - Rearend 1 12-19-2003 05:21 PM
Stude to Chevy engine swap Dawger General Rodding Tech 3 07-11-2003 08:15 PM
