trans swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2006, 07:54 PM
trans swap
I'm doing a 700r4 trans swap on my 68 camaro, Does anyone know what speedo gear I will need for 17 inch wheels?
Old 04-01-2006, 09:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you need to know the rear tire diameter and gear ratio of the differential to select the correct speed-O gears for the trans
Old 04-02-2006, 11:08 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
There is a speedometer gear calculator link somewhere on Bowtie Overdrive's website.
I have some links in the Speedometer Information thread I had in here a while ago, do a search for "Speedometer Information" and you should find it.
You'll need your axle gear ratio AND tire size.
Old 04-02-2006, 11:12 AM
Rick 5150 69's Avatar
Try here http://tciauto.com/tech_info/speedo_gears.htm
Old 04-02-2006, 03:11 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Only problem with TCI's site is it want's one of the gears already in there, the other site tells you what to put in for both drive/driven gears.
Old 04-02-2006, 10:12 PM
http://novaresource.org/speedo.htm
Old 04-03-2006, 08:34 PM
Trans swap
Thanks to all who responded. That was the info I needed?
87 Trans Am Engine Swap Miserlou57 General Rodding Tech 3 02-01-2005 03:32 PM
Trans Am Engine Swap Guitarman Engine 2 04-26-2003 07:54 AM
c4 trans swap FASTFORD Transmission - Rearend 3 05-07-2002 11:11 AM
63 falcon (trans - rearend) swap melbishop Transmission - Rearend 2 04-16-2002 05:03 PM
