Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans swap in 90 caprice
  #17 (permalink)
Old 05-31-2011, 09:57 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by cudablack2004
ok just went out to check the trans out very good! It has 13 pan bolts 6" tailshaft and a vacuum modulator in the right side....which identifies as the th350 27 splines and has a convertor with it! Now as i start all over what will i need to do to make that swap possible? Im kinda upset i didnt pay too much attention but i kno i have a way stronger trans that will hold some hp and maybe roll some heavy wheels if i decide to put my 18s on
here, instead of retyping, i copied and pasted what mentioned up on page 1.
if its a th350, you will have to run a vacuum line from that nipple, to a full vacuum source on the engine. and you will have to buy a kick down cable for the 350 as the cable for the 200c and the 200-4r are not the same as a th350.
oh and i forgot to mention 1 good thing, you dont have to do a thing to the driveshaft as from end to end, they are the same length.
