Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans swap in 90 caprice
  #19 (permalink)
Old 05-31-2011, 09:47 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by cudablack2004
it doesnt have a plug at all so i guess its a non lockup not sure what difference that will make or what ill notice. And i do have a cable with it! Will my 200r4 speedo work in there they look similar? Will the convertor bolt up to my flywheel? And would that be a better choice over the 200c or should i sell and start over?
the 350 is quite a bit stronger than the 200. if mileage isnt all that important to you with this vehicle, id say just put it in and not worry about lockup.
the speedo cable fits on either trans, and the converter will bolt up to your flexplate, just have to buy converter nuts and bolts. 3/8x24x3/4 on the bolts, and 3/8x24 on the nuts.
