trans swap from camaro to truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2011, 11:13 PM
hi all, i searched threw some other post and never really got a straight answer, and if i missed one that discussed this i am sorry for the bother.
ok, i am looking to take a 700r4/4l60 out of a camaro v8 and put it in a c1500 pickup2wd v8 my concern is if there any modifications that would need done to make it work or will it just go right in? i know i may have to change the speedometer gear to adapt the electronic speedo if its mechanical/cable. and that the casing is thinner from a car to truck but im not going to be doing any towing or anything like that with it, its a cruiser not a worker.
thanks to all that lend advice
Old 05-21-2011, 11:38 PM
SSedan64's Avatar
What Year Truck?
Engine? Carb or EFI?
Shouldn't be much trouble. There's no difference in Case thickness between Truck & Car with the TH700R4.
A 700R4 from 87-92 or up to 93 from Camaro/TA is best, they have the most factory upgrades. The Tailhousing is different on the F-body Trans & may need to be swapped to bolt up to the Truck Crossmember.
TV cable is the most important part to install correctly.
Old 05-22-2011, 12:04 AM
actually there is thickness difference in most trucks there is heavier duty casing the thicker cases are stamped with the letter K on the bell housing. and yeah tv cable adustment is key. the trucks a 92 sbc350 tbi
Old 05-22-2011, 12:39 AM
SSedan64's Avatar
I've seen the thicker Cases on the 3L80/TH400 & 4L80E but, not the 700R4/4L60. Are you thinking of the 4L60E/4L65E?
Old 05-22-2011, 01:01 AM
no, they are more common on those but they also did it on the 700r4/4l60 and 4l60-e
the main reason i asked about the fitment of the car to truck is worried that the output shafts would be shorter, i don't see why they would on a 2wd but GM has done some weird stuff .. like a 700r4 off a 2.8v6 or 3.1v6 besides bolt pattern they have fewer frictions(clutches) in them so behind a v8 they wont last long, never new that until i pulled one apart from an s10
Old 05-22-2011, 01:09 AM
SSedan64's Avatar
The only 2WD 700R4 that the Tail length & Output Shaft length is different on is the Corvette, 82-96 is about 7/8" shorter.
All are 27-spline Output Shaft. The early 82-84 have 27-spline Input Shaft, late 84 to 85up have 30-spline Input Shaft & auxillary Valve Body.
Yeah, the 2.8L, 3.1L 3.4L V6's are 60* Engines/Bells.
Old 05-22-2011, 01:17 AM
awesome that gave me confidence of not wasting money thanks man
Old 05-22-2011, 07:30 AM
tnsmith10's Avatar
when will it rain???
late 87-up has auxillary valve body bud.
Old 05-22-2011, 03:05 PM
SSedan64's Avatar
Good catch there Tn. I need to quit typing when it gets late.
Todd
Old 05-23-2011, 06:22 AM
tnsmith10's Avatar
Todd
yea, same here when i get up too early and start going at it. i do the same thing...
Old 05-23-2011, 10:20 PM
by chance anyone know what the standard size slip yoke is on these so far i got two 700r4s with shorter splines on the out put shaft then whats on the original that came out .. the count is the same , just the lengths are different from the original as seen in the pic they are about 2 inches shorter
first time project:78 camaro w/454 efi engine swap from a 2000 truck need pointers alex.trujillo48@yaho Introduce Yourself 2 09-28-2010 06:43 PM
49 chevy truck Chassis swap 80 Camaro questions Blankenship Hotrodding Basics 39 09-12-2009 06:44 AM
4 Spd Ford truck trans swap questions 68F100 Transmission - Rearend 2 01-06-2009 07:54 AM
1968 Camaro trans swap info needed J.D Transmission - Rearend 4 07-14-2008 08:24 PM
Trans Swap 4l80e In 69 Camaro NU BREED Transmission - Rearend 2 08-16-2003 11:28 AM
