Trans swap s-10 to 1500? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2009, 07:14 PM
I have a 94 GMC 1500 4X4 with a 5.7L and a bad 4l60E. I found a rebuilt 4l60E out of a 94 S-10 with a 4.3 Vortec. Will this work in my 1500 without any mods? i.e put it in, plug it in and go?
Old 11-10-2009, 07:44 PM
MAYNARDTRUCKIN's Avatar
Last journal entry: new pic
the help u need
Yes they will swap with each other. The only difference is some of the clutch packs. The v8 will have more clutches on some of the packs and also might have more line pressure, but that wont make much of a difference.
Old 11-10-2009, 09:26 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Less clutch packs and the torque converter specifically set up for a V-6's torque output, and installing it behind a V-8 and adding a good 1000 pounds of a heavier vehicle to ask it to move around, you are just asking for that transmission to fail miserably with this swap.
Not a good idea in my opinion.
Old 11-10-2009, 09:44 PM
I have a 700r4 in my 70 chevy pick up with a 375horse 350 3.73 posi. the trans came from a 89 s10 and the only thing i did was rebuild it. It has been in my truck for six years now and no problems what so ever.
Old 11-11-2009, 04:27 AM
OK>>What if I used the tc from the V8?
Old 11-11-2009, 07:25 AM
sqzbox's Avatar
My pipes are my music
Lower stall speed.
Old 11-11-2009, 09:18 PM
Rexnfx's Avatar
It will plug and play
But, there is subtle differences in the actual hydraulic control. Meaning, a 6 banger in a light vehicle doesn't have the boost fluid pressure a V8 does, factory. So actually, its kind of a light duty transmission, basically, w/o getting into the theory of it Good luck
questions for a auto to manual trans swap johnnyt5646 Transmission - Rearend 0 02-05-2009 02:52 PM
trans swap phatfalcon70 Transmission - Rearend 4 01-12-2009 12:28 PM
1993 Silverado K1500 auto to manual trans swap.. FinishLine Transmission - Rearend 1 01-11-2009 09:42 PM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 03:14 PM
7.5" 10 bolt gear swap offroadin Transmission - Rearend 1 06-28-2004 06:39 AM
