trans temp - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2003, 09:34 PM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
trans temp
where is the best place on a TH-350 tranny to put the trans temp sender? thanks
Old 11-30-2003, 08:45 AM
NorthStar's Avatar
Pan or supply line going to the cooler.
Old 11-30-2003, 09:32 AM
thanks Greg Latvala
Old 11-30-2003, 10:51 AM
Decadent pianoplayer
And what is a good operatin temp. for a prepped Th350 with a B&M 2000 stall converter?
Old 11-30-2003, 12:07 PM
NorthStar's Avatar
160-190 degrees
It gets cooled by radiator so eventually it stabilizes at same temp as coolant when just cruising around.
I have a gauge on my truck it takes a little while for the oil in pan to warm up. If it was in cooler line it might read a little faster.
I did have it get to 220 once when fluid was low and trans was really slipping. If a person was going to pull a trailer I think it would be good to have a a gauge.
