Trans temp gage grounding issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2012, 06:58 PM
I installed a B & M trans temp gage in my 72 Chevelle. Its located on the return steel line from the cooler back to the trans. I wired it per the instructions, Switched Power, Sensor and a wire to eluminte the light. The gage works fine (minus the back light) until I land the ground wire on the gage. Once I do that, the back light eluminates and the temp gage drops down to zero.
Would anyone have any suggestions?
Old 07-18-2012, 07:54 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
The body of the light socket
which is grounded is touching the terminal that goes to the sensor thus grounding the gauge sensor terminal causing the gauge to go to 0.
vicrod
Old 07-19-2012, 06:59 PM
Thanks
Thanks Vicrod!!! I would have never thought of that!!! It works now.
PS. Thats a beautiful ride you have there!
Old 07-19-2012, 08:12 PM
vicrod's Avatar
life is a ride
Glad that it worked out.
vicrod
oil temp gauge instead of trans temp gauge mocheez Electrical 8 01-01-2012 01:02 PM
AOD Temp Gage Install Sick467 Transmission - Rearend 4 12-04-2010 09:32 AM
Fuel and Temp Gage A56Nomad Electrical 1 05-29-2008 05:17 PM
trans temp 1969NovaSS Transmission - Rearend 4 08-30-2005 07:46 PM
trans temp Old School Nut Transmission - Rearend 4 11-30-2003 12:07 PM
