trans or trasfer case ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2010, 11:32 PM
kc0kfg's Avatar
kc0kfg
Well My 97 burb has been making this "ting" noise for a while when going from park to either reverse or drive,thought it was a u-joint since the sound was like a joint going bad, but now it wont engage 4 wheel and the "ting" seems louder.
The "ting" would happen in either 2 or 4 wheel when going from park to any gear.
When I try the 4-wheel now it just blinks I know it could be the servo but would that make noise even when just shifting into drive from park in 2 wheel?
If it is the transfer case can it just be swapped without pulling the trans?
The truck is a k1500 with the 5.7 gas motor
Thanks Brian kc0kfg
Old 02-01-2010, 11:38 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Still could be a U-joint. There is a 'shift motor' on the T-case that can be changed out. This is what physically shifts it to 4WD.
Mopar 727B car trans bolt up to 4x4 transfer case MOTOR HEAD Transmission - Rearend 1 03-16-2008 10:35 PM
cleaning trans case tomthecomic Transmission - Rearend 6 01-04-2008 06:44 AM
Jegs 350t trans..... No good!!!!!! tiresmoke55 Transmission - Rearend 15 08-11-2006 11:24 PM
727 Torque Flight trans problems Steves66 Transmission - Rearend 5 06-30-2006 04:11 AM
Do I need any additional trans cooling? Z-Money Pit Transmission - Rearend 1 12-17-2005 08:03 PM
