Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trans tunnel clearance?
Old 09-16-2008, 04:03 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
That's a trick I learned from the custom motorcycle guys...that's how you position a snug fitting front fender to mount it and maintain enough tire clearance so a rock caught in the tread does not wipe out the paint when it cuts a dent from the inside out of the fender as it rolls through.
Later, mikey
BE different....ACT normal.
